Changing baud rate multiple times. I know this change is being applied while viewing the output with an oscilloscope.
Tested the cable with another TTL UART device with 3.3V logic. The cable checks out.
Changed the base station module to a rover configuration with the same settings. The results are the same.
Set up the base station on a roof mounted on a tripod and drove a robot around with the rover station attached. Everything seems to work here as I was able to see the Satellites with their corresponding SNR levels in ReachView. Also, I was able to successfully map out the rover’s course with RTKPlot.
Tried different output formats other than NMEA. No luck.
Tried setting the output to solution 2 with the same results.
Any help is much appreciated. I feel like I’m missing something simple since it’s happening on both modules.
Thanks for the response. I set the stop bits to 2 with no change in results. I did find something interesting though. When I turn the solution 1 and solution 2 output off in ReachVeiw, I still receive the same “trash” output…Not sure what this means. It happens on both modules.
