What do I need to do to fix this? I need the latest version of APM.
Are you sure you are using the emlid raspbian image? I can’t see apt checking the emlid repository.
You’re using an extremely old image! Please flash SD card once more with a more fresh one. The image with the hostname navio-rpi
has been deprecated for a long time. Sorry, if you haven’t heard of it!
Could you give me some help as well? I can update the pi but it does not allow me to download ardupilot.
Do you know why?
Thanks
ArduPilot has been part of our Emlid Raspbian for more than a year. Please, refer to the docs for how to setup everything.
I have followed the same step as what it says, still no success. Do I have to install the telemetry? As I do not have one yet.
Also, I did all the steps as it says, but when I reboot, the same welcome page appears again. What I have done wrong?
Thanks for your help
To transmit telemetry over WiFi you have to setup your GCS’ IP address in /etc/default/arducopter
. Just simply set TELEM1="-A udp:<your ip address>:14550"
Hi Koby,
I did as described in the docs. I changed the IP address to my laptop address. Do you know what else is wrong?
Did you reload config and restart ArduPilot?
Yes, I did. When I type in start arduplane, the annoying thing is nothing happened. Is it supposed to be like that? How do I know if I have done correctly? No messages at all.
You don’t get any messages after successful start of arduplane. To make sure that it functions normally, type systemctl status arduplane
. You should see Active: active (running)
I tried. Do they look correct to?
When I open mission planner, the plug is still red color. Any advice? Thanks
What is the output of ifconfig?
Hi Koby,
I think it is working now. Thank god. I played with mission planner. it is connecting now. cheers
