Help! I’m confused lol.
Setup
Latest mission planer
Both base and rover all talk to each other.
Latest reach update.
Reach base in AP mode or with USB Conection to laptop.
Telemetry radio 3DR v2 (cable modified as per docs) and connected to reach base unit.
Sik settings for both ground and air end changed as per docs.
Pixhawk running ERB firmware.
I just cannot get the base radio to connect to the air end. I’ve tried usb to reach then picking the com port In MP and I’ve tried connecting to the reach base via tcp, I know the ip of the base unit but unclear on the port number but neither method works. I’m going to assume that a reach unit connected via usb and the 3DR radio should connect? Or must it be via AP.
3DR radios connect fine (in sik mavlink mode) if reach base is omitted. But nothing in sik RawData mode
What am I missing?
All the best
Andrew
