i followed the instructions stated in the emild documentation on the hardware setup. after doing the compass calibration as shown in the pictures below the mission planner shows a gps no fix sign. please help thanks !!! i went to an open field and when checking the temp file it shows gps pass
GPS status is 1 (present but no fix), satcount =0… It is a normal state just after boot. Depending of the date of the last GPS fix, you may have to wait some time before everything is updated in the GPS memory. Clear sky view is needed. You can also move your GPS antenna away from Navio to be sure there is no EMI interference.
3D Fix msg appear when 4 sat are detected. Horizontal position could be away (far) of your real position. When hdop drop below 2, position is better.
hi what do you mean by the date of the last GPS fix. and i have also tried to configure in the mission planner according to your settings in open field but the gps still states no fix is there another way to go by it
this is how the connection of the externally connected gps connected to the uart port and 12c port looks like as i still am unable to connect to gps it stills say not fix
Try to avoid sharp bends in the antenna cable. Sharp/narrow bends might cause signal reflection inside the cable.
Try to add a groundplane under the antenna. I use plywood with aluminium tape or big metal lids of jars. The bigger, the better, but the copter should still be able to fly. 10cm diameter/side length should do.
Check if there is any dirt/dust in the antenna connector. Use dry air from a can to blow out both connectors. Do not use air from a compressor, it may contain oil vapor.
With everything running, push onto the antenna connector with your finger for a while and see if the GPS sees any sats.
The “date of the last GPS fix” means how long ago the GPS last had a lock/fix. The longer the time since the last lock, the longer it takes to aquire one.
hi i have connected an external gps to use it to get a gps fix on mission planner. however the internal compass with the gps antenna does not seem to be working. may you show me the configurations setting in maybe sudo nano /etc/default/arducopter or mission to show how you did it with the internal compass to get a 3d fix on mission planner to do autonomous missions.
If you want to only use an external GPS, you can. To use Internal GPS or both Int and Ext you need to plug an antenna. Emlid is a good one (amplified) at low price.
Some settings could be changed to use only the external one:
GPS_TYPE is set to 0 (none)
GPS_AUTO_SWITCH is set to 1 (Use best). If set to 0 (Disabled) moving map in mission planner is not receiving position data (???).
RMK: GPS status in moving map display (nSat, hdop) stay at zero.
GPS time is also missing (not updated)… in status screen
