I have a Reach M+ (RCH102). I followed the setup instructions (https://docs.emlid.com/reachm-plus/common/quickstart/first-setup/) through to the “Updating Reachview step”, but now I am unable to connect to the device. When it is plugged in the orange led is solid, but the blue and green leds are off. On my phone, I can see the reach:xx:xx network, but ReachView is unable to connect to it (neither when my phone is on the reach network or when I am on the local wifi), so I don’t have any firmware information etc.
It was connected to a hotspot wifi from a phone (a different phone from the one I had ReachView on, which was connected to the same hotspot during setup). It is not connected to an antenna, but I did take it outside with no change.
I haven’t received my antenna yet (it is on order), so I can’t test with the antenna at the moment.
It seems like I should still be able to connect to the M+ using ReachView without the antenna though, right? Would flashing the firmware be the next step?
May I ask you to reflash your Reach device? Please, follow this guide to accomplish it and let me know what will be the LED status after the reflashing procedure.
Thanks, I will reflash the device and update here with the results.
Is there, by any chance, a beta Mac OS X firmware tool I could try out? I see it mentioned as coming soon.
