As I am not very familiar with network configuration on the Emlid Edge or the raspberries in large, can someone point me what are the steps to disable Edge hotspot and configure so that Wifi will be in client mode at boot ?
Unfortunately it is not for this problem, because the problem occur exactly after following this guide
Yes you will be able to switch between networks once you have configured a network and saved it, but at reboot your EDGE will be back on Hotspot. What I am asking is how to disable hotspot config to use my EDGE as a wifi client at boot.
I am using the edge as a rover, there is a router and a PC on the rover, the PC sends Mavlink commands base upon video capture to ajust speed, now every time the EDGE reboot I have to connect to the edge hotspot, browse to the wifi setting page, click on the switch button, reconnect to the router on the rover… I would like not to do that + the fact that I can loose comm at any point and the hotspot will come up, resulting in loosing comm between the PC and the EDGE…
and the /etc/wpa_supplicant/wpa_supplicant.conf is updateted with the config to connect to my network
The problem that I see with this is the can0 interface is now disabled and the wifi led is not working anymore, but, evreything else works as I wanted… I am pretty sure there is a better way to do this, I am open to any advice on this.
