Thank you for the reply!
Away from my computer so can’t do screenshots etc right now but trying to set “MNT_TYPE” to “servo”. Also tried some of the other available settings bu with no change.
I have connected two small standard servos to act as roll and tilt axis to pwm-pins 13 and 14 on the navio2.
Hope this clarifies things!
I wanted to check if you resolved the issue? If it still occurs, try to connect servos to the pins 1 and 2. I also still need photos of the hardware setup.
