Hello all,
I am not sure what I am doing wrong but I am having troubles trying to get my ESCs to arm properly with Mission Planner. Here is my setup.
Transmitter: Flysky FS-I6X
Receiver: FS-iA10B
ESC: FPVDron 2-4s 30A SimonK w/ BEC 2A
Mission Planner 1.3.63
I have the Navio connected to the USB power adapter and Lipo plugged in.
The PPM (channel 1) of the receiver has jumpers to the Navio PPM.
All 4 ESCs are connect on channel 1 to 4. Only 1 ESC (channel 1) has the RED line connected. All other ESC have the power line removed. Also, I did successfully complete the Radio Calibrartion.
- Turn on flysky transmitter.
- Open mission planner and connect to Navio via UDP. I have already completed the Radio calibration and I set the mode to “Stabalize”.
Navio LED blinking blue at this point
Message tab reads following:
Frame: QUAD
ArduCopter V3.6.5 (b5f637fc)
- Click on the “Initial Setup” button
- Click on >>Mandatory Hardware
- Click on “ESC Calibration”
- There is a “Calibrate ESCs” button. I click on this and follow the instructions. I have the throttle stick UP.
a) Disconnect USB.
b) Disconnect Lipo.
c) Wait a second and plug in Lipo.
At this point, I see the navio bootup via LED geen status. And the ESCs come up making a few beeping sounds.
But at this point the LED status on the Navio cycles between red, green, yellow and blue. I believe this status is the Arm failure but I am not sure what is causing this. I even tried this video but no success.
I even went through other threads of individuals who had similar issues. If anyone can suggest or help guide me past this newbie part, I would greatly appreciate it.
