I’m having trouble getting anything but single since the last firmware update. Everything was fine before, and now, no matter what I do, I can’t get a fix. Same configurations, locations, etc. I’ve tried every darn setting I can, reset to defaults, etc. Nada. If I connect the base to a CORS, I can sometimes get a fix, sometimes just float. But, I can’t have internet connection in the current field situation, and besides, it should get a fix without additional correction. Prior to this update, I had little trouble (once I got everything tuned up).
I realize this is one of those general issues, but this is costing me money, and I don’t know what else to try.
Well, the last update changed nothing in the positioning engine, moreover, it was a slight interface change, nothing more. What is your average SNR level?
I’ll go out and set things to default and collect logs. It’s raining here now, so, it will be a little later today. Thank you guys for trying to lend a hand. I genuinely appreciate it.
The refrence file from CORS. If you enabled logging for correction data/base, it should there.
Zip contained 4 files. 2 raw files from rover ( 2 different time periods) and 2 solutions files. Solutions files are processed files from reach, not for post processing
I guess I’m misunderstanding something. My issue is not getting anything but single when not connected to a CORS. So, there’s no CORS correction. I ran the base for six hours Friday, with close to ideal conditions, and never got a fix. My apologies if I’m missing something here.
Are you looking for a way to show real time correction data that will give to real time cm accuracy or do you need to do it later with post processing?
Im not that familiar with coors, but can you download historical data?
I assume you have login info to cors, and when you are setup reach to recive correction you can see grey bars in the status window? If so, reach is getting them and by enabling raw logging and correction data logging, you should everything needed. You just need correct settings to get fix
I’m trying to get a fix without CORS. If I am connected to CORS for real-time correction, everything seems okay on the base. However, without CORS, I can’t get a fix except for single. I need the base to achieve fix, so I have decent accuracy while in the field. I have tried every setting I can come up, following the suggestions folks have given in the forum, and, using the exact same settings that I used with success before the update. No matter what I try, I can’t get a fix.
