Wondering if anyone can help. UAVCO maintains a publicly broadcast streaming GNSS/GPS data from some of the PBO, COCONet, and TLALOCNet stations in the USA. They Realtime 1-Hz streams from these selected stations are available in both BINEX and RTCM (versions 2.3 and 3.1) formats via NTRIP.
So I set up my base with this address /port, my username / password. I know it connects properly to the caster, as the pull down for the mount points shows all their available mountpoints. So I chose the one located closest to me, and then hit apply, and I don’t get any corrections data at all coming in. Any thoughts on the problem?
As a sidenote for VRS. If you use this , your Reach need enough good satellites to output a position. If it cant, it would not work as VRS need to know where your Reach is located. (for those who use Reach inside etc etc)
I was able to get working today. For those that might happen to use UAVCO, here are the settings:
The source for the RTCM3 stream is XXXX_RTCM3, where XXXX is the station. Also, use port 2101 (raw). Set to RTCM3.
If you copy/paste the following link into a Firefox browser window you can see all the streams that are available at that moment: http://rtgpsout.unavco.org:2101/
If you don’t see xxxx_RTCM3 in the list, I was told it may be temporarily offline.
