I plan to use a PPK (L1/L2) set up for my UAV, with as base a Reach solution.
My flights are urban flights at low altitude, there are buildings, and the max distance from the base will be around 400m.
My question is: for this kind of use, is there any significativ difference between using Reach RS2 or RS+ ?
I’ve heard that RS2 would be better for long range, but in my case, this is the short range.
thanks for helps.
