I’m trying to aquire GPS coordinates from APM. I tried to use some methods from the code without success, then I tried to include the Ublox library at APM to get this coordinates. I had success using it, but what I really want is to get values for X and Y displacements in meters, is it possible to get? I also would like to have the NED speeds, if its possible.
Thank you for helping, but I don’t understand how to catch the mavproxy information in my code. what I saw at the documentation is that mavproxy sends information to a selected IP on network. I’m trying to catch the coordinates, put it together with another parameters and save it on a .CSV file at a directory in RPi.
APM (or MAVProxy) can send MAVLink on a local port, so you can read it directly on Raspberry.
You can open that port in C++, parse the MAVLink protocol and extract the coordinates from the corresponding GPS message.
But I didn’t had success while installing mavproxy, when I type “python setup.py build install --user” I receive an error and I cannot install pymavlink and I’m not able to run MAVProxy because it cannot load the modules.
The commands were fine, but I still cannot install the mavproxy.
I’m trying to use the functions inertial_nav.getposition() and inertial_nav.getvelocity()
I don’t receive de X and Y coordinates, only the Z. the velocities seems to be wrong too.
I’ve been trying to figure out how to send MAVLink on local port and I am not sure how to do it. In particular, I would like to send MAVLink both to Mission Planner and to Raspberry Pi itself (to extract the coordinates parsing the protocol).
Do I need to use two telemetries when I start ArduCopter (i.e. -A for the GCS with Mission Planner and -C for the local port)?
Or do I need to send the MAVLink through Mission Planner?
@mariagf there are numerous ways to do that, using two telemetry options may be the simplest of them. Just specify 127.0.0.1 as IP port for one of telemetries.
