Truncated or non-floating, looks the same
RE: Emlid Flow v8.9; CSV Export
Exported Survey (free version) in .csv file format results in what I referred to in an email sent earlier to Emlid support as a Go Board, seen above with orange tokens. The exact same dataset exported as a .dxf are seen here with smaller red dots which appear to be full floating decimal values.
If the above comparison to Go has you curious, below is a real Go game board:
The preferred workaround to this issue of non-floating decimal or truncated coordinates in the .csv files produced by Emlid Flow is to use the export option Shapefile. Shapefile exports preserves the attributes, whereas the .dxf option strips away most attributes:
Hi Kelly,
Sorry that it’s so quiet here.
Yes, the coordinates from the DXF file are not rounded. So they have more decimals than the coordinates from the CSV. But why do you need those decimals? Is it for a specific application?
Hi Julia,
Thank you for your reply.
In general, double-precision floating-point formatting provides the best resolution, widest dynamic range and most accurate numeric representation of a thing in sight, sound, or space.
For example, which image below has the most number of points?
A
B
The answer is neither A nor B; both images have exactly the same number of points!
C
More fun with numbers - just received from my friend Brian: Numeric Bliss | Brian Dyer Stewart
And in case you were wondering, these RTK points were collected using the RX on a magnail in the curb at Ellsworth City Harbor Park on 20230629 at ~0700 UTC-4
magnail in curb at Ellsworth City Harbor Park x 500
