The pins are titled bind, throttle, elevator, aileron…, AUX. We think it should be plugged into AUX, but we also tried throttle and neither worked. Which one is it supposed to be?
We are sure that we bound the RC receiver successfully. (to a spektrum DXe)
We have connecting 3 servos to the LemonRX. If we connect them to the ‘Ailerion’ and ‘Elevation’ and ‘Rudder’ channels, the servos move with the joystick. If we connect them to ‘Gear’ or ‘Throttle’, they do not move with the sticks but do receive signal (they move slightly immediately when plugged in).
UPDATE: We purchased a Lemon Rx 6Ch LM0028 receiver which apparently does not output ppm. We’re switching to the Lemon Rx 7Ch LM0039 receiver which should work
