I am going to invest in a trimble nomad and I know that later versions of carlson ServCE are compatible with reach, but has anyone used Survey Pro via bluetooth to connect to an RS+, or know if it can simply connect using the NMEA output?
Hi @aj1,
We didn’t conduct tests with the Survey Pro. However, if this software supports NMEA input over Bluetooth, there should be no issue to integrate it with Reach RS+.
You just need to pair the Survey Pro device with Reach first. This guide describes how to pair the devices using Bluetooth.
