Traverse Height Difference
This might be blindingly obvious…if so my apologies.
When I select a point to traverse from, I can enter 2D distance, Direction Degrees and Height Difference.
Why am I not able to enter a negative height difference?
The use case is I want a point to be x metres lower than my reference point. That means that when I stake that point I should automatically get a cut value. At present this isn’t possible in EF.
Many thanks for advice here.
Just a quick check, I was able to do it
Works in both global CS and custom coordinate systems . This is on IOS
Thanks @davehofer1993 I cannot on iPhone with the latest iOS I simply get a numerical only keyboard.
On iPadOS I just realised I can. I get a full keyboard.
Are you able to enter negatives on the iPhone?
Perhaps this is a bug?
Like you said that would depend on your keyboard , I don’t have iPhone
No iPhone here either… but wondering if a work around until then, can you cut & paste a “-” ?
Works on android phone
Thanks @davehofer1993 and @timd1971
I’d be keen to hear from Emlid and also from other iPhone users. It’s frustrating not being able to simply type a negative number with my iPhone. If there’s something I can do regarding keyboards I’d be keen to hear that. I haven’t found anything in my searching.
I see the issue is that you’re only given the numeric keyboard. If I copy a “-“ and paste it in, then I can enter a negative value.
I don’t know if there are any other keyboard options to make this simple, but it will likely be a button or toggle that should be implemented in the software.
Shame it wasn’t noticed during development.
I was able to reproduce it as well on an iPhone, we’ll get it fixed! Sorry that we let this slip into a release. The temporary workaround is to copy and paste a value, which is definitely not ideal, but this is the only solution I can suggest until we patch this.
Thank you for the quick update @igor.vereninov I see this is now fixed in the latest iOS release of Emlid Flow!! :clap: :clap:
Yes. We resolved this issue in version 11.3, which was released today! :tada:
If you have any other questions, feel free to start a new thread or reach out to us at support@emlid.com.
