I would like to use my REACH M+ to record events each time my Thermal camera is triggered but there is no hotshoe of course. What signal/inputs does the REACH require in order to record an event please?
I am looking at activating a relay via PWM to connect the camera trigger signal cable to GND to fire the camera, so if i could do something similar for the reach that would be ideal.
Thanks
Hi @malcolmdavidge,
If you know how to get the feedback from your camera, you can use Time Mark1 pin on reach M+ C1 port to save events.
Please note that Reach’s GND pin from C1 should be connected to the camera’s GND.
Very helpful thank you @svetlana.nikolenko
i will give it a try and let you know how it goes!
I would be very interested how you realize that and if the results are good. I think there are several challenges regarding the thermal camera (identifying the exact frame for each timemark) and I would be interested to see the accuracy of youre result.
Which camera are you using?
@tobias-dahms https://www.drone-thermal-camera.com/products/workswell-wiris-pro-uav-thermal-imaging-camera-for-industry/
Hi Svetlana,
Can i just confirm i take the GND form the camera to C1, and for the time marks it is ok to use 5V? not GND.
thank you
Hi @malcolmdavidge,
The GND pin from port C1 should be connected to the camera’s GND, and the Time mark1 pin to the camera shutter signal.
What are you flying this on? I sold my M210 and XT2 and looking for an affordable good camera that I could mount on my I2. Thanks for any feedback on your setup and updates with the M+ integration.
hey tim,
This is under an M600P. It has been integrated to an M210 before but not an I2 that i’m aware of - probably struggle tbh. As for afordable … well lets just say its in the same ballpark as XT2.
i tested the M+ integration the other day. it kinda worked but i had the trigger signal open for too long and the M+ was set to 14Hz so i got about 9 events for every trigger!
More work needed
Cheers, Malcolm
Hey Malcom, a little off topic but related. I am wanting to put my Sony A6000 on the M200. If I hook up the Reach M+ or M2, can the M+ be set to trigger the camera every so often or will I have to just set the A6000 to take a photo every second, or 2 seconds, etc and just use the hotshoe to record the time stamp? If the camera is on interval photos then that should actually work just fine. I ordered an extra GPS bracket for the M200 and I will just remove the white antenna and replace it with the M2 antenna.
Any feedback will be appreciated. BTW, I found a sweet deal on the M200 and an XT2 so I went ahead and brought that back in
