Hi
I just saw that you have a “Time Mark” pin on the DF13 connector. The documentation states that it is a direct connection to the Ublox module. Does somebody know to which specific pin it is connected on the NEO-M8T?
I would be interessted on the 0.25Hz-10MHz frequency output signal of the Neo M8T for the base station and I would like to avoid soldering onto the actual Ublox hardware.
Thank you very much and regards
Andreas
@sixtimesseven Hi!
I think that you need “Time Pulse” pin, not “Time Mark”. It is labeled as PPS in our documentation and is connected directly from Intel Edison to TIMEPULSE pin on NEO.
Thank you for your quick replay. Yes I know that the NEO has Time Pulse Pins. What I was wondering was wether these are connected to the DF13 outputs or not.
Apperently not. to bad that means I have to solder them directly to the NEO.
Thank you and regards
Andreas
Hi @sixtimesseven, It would be great to know if you made any progress with this?
Having access to the Time Pulse pin would be extremely useful for a number of applications.
Please let me know what you did in the end.
Kind Regards
