Hello, I bought a cable from Tuffwing for the Sony but I forget to buy one for the Canon S110 so I made a circuit of my own that output normally 3,6 Volts and 0,05 Volts when the camera take the picture.
Can I use the Time Mark Input of the Reach or I need 0,0s Volts normally and 3,6 Volts when taking picture?
p.s.
I will change the resistors until I get 3,3 Volts
Same question here. In https://docs.emlid.com/reach/electrical-specs/ says that all logic pins are 5V tolerant. Also, it says that the time mark pin includes an over-voltage clamp and a current limiting resistor. @igor.vereninov But just to be sure, will a constant 5V on the time mark pin cause an overheat and burn the circuit?
