Apologies if I’ve missed it, but I haven’t seen the thread size for this antenna in the specs, or on a quick check of the forum. Can anyone tell me the thread size to make it easier to order some bolts? A pin in the hole suggests you can go almost 10mm deep.
Hey guys,
Sorry to be late in the game! The connector is indeed SMA for the antenna. It’s MCX on Reach.
Just a quick trick that may help you further on: we have 3D models available in our docs. For helical antenna model, you can check the Specs part. This helps see how well it fits in your setup.
