zivyfeng
(Zivy)
1
Hi guys,
I recently use cgroup to limit the resources, while when I install cgroups-lite, it shows
$ sudo apt install cgroups-lite
Reading package lists… Done
Building dependency tree
Reading state information… Done
E: Unable to locate package cgroups-lite
But I have successfully installed cgroup-bin cgroup-lite cgroup-tools cgroupfs-mount libcgroup1
And there is no cfs_period_us or cfs_quota_us in the /sys/fs/cgroup/cpu.
pi@navio:/sys/fs/cgroup/cpu $ ls
cgroup.clone_children cpuacct.stat cpu.shares tasks
cgroup.procs cpuacct.usage notify_on_release
cgroup.sane_behavior cpuacct.usage_percpu release_agent
My kernel is
Linux navio 4.4.36-a7765e7-emlid-v7+ #41 SMP PREEMPT Mon Mar 20 18:48:32 MSK 2017 armv7l GNU/Linux
Does anyone can help, thank you!
Hi @zivyfeng,
It seems that to enable CPU cgroup Linux kernel must be compiled with the next parameters:
CONFIG_FAIR_GROUP_SCHED=y
CONFIG_CFS_BANDWIDTH=y
You can recompile the kernel with these parameters. To build the latest kernel version use this source code.
zivyfeng
(Zivy)
6
Hi, @tatiana.andreeva,
Thanks for the help, it works.
But it raises another problem, after compiling the kernel and rcio-dkms, PWM has failed when I run PX4.
ERROR [linux_pwm_out] PWM export failed
ERROR [linux_pwm_out] PWM enable failed
ERROR [linux_pwm_out] PWM period failed
ERROR [linux_pwm_out] PWM: Failed to open duty_cycle.
ERROR [linux_pwm_out] PWM output init failed
By the way, the PX4 version is
PX4 VERSION: v1.6.5-1492-g22b617d
when I typed lsmod it shows
Module Size Used by
rcio_spi 16384 0
rcio_core 36864 1 rcio_spi
Is there any solution? Thank you!
Hi @zivyfeng,
Have you already tried to run ardupilot? May I ask you to do it in order to make sure it works?
zivyfeng
(Zivy)
9
Hi @tatiana.andreeva,
Yes, I have run the autopilot on the new compiled kernel, and it printed PWM errors.
zivyfeng
(Zivy)
14
Thanks for the help, I used the v4.14 version kernel code, it works. BTW, using an older version code, it still has errors.
system
(system)
Closed
15
