The Radio shown on the picture is intended for my zed f9p project, i just wondering if it is posible to use for Reach M2?
try this
thank you very much
Hi Joseph,
Reach M2 requires UART radios. As far as I know, your radio uses UART, so it should be compatible with the receiver. Reach M2 pins are 5V tolerant so that you can use the 5V logic level radios with it.
To connect the radio, use the lower JST-GH port (S1). You will need to connect Reach 5V, TX, RX, and GND pins to the corresponding radio pins.
To start working, you need to attach 2 similar radios to Reach receivers, and set the receivers up as a base and a rover.
thanks for that. i just purchased 2PCS M2, im excited to build my first RTK.
waiting for the progress on my onder.
