The Pix4D & Emlid Scanning kit: capture precise digital models in minutes
Meet the Pix4D & Emlid Scanning kit that combines advanced photogrammetry with RTK precision. The Scanning kit is designed to quickly capture accurate digital models when documenting trenches and as-builts, performing volumetric measurements, and enriching aerial data with terrestrial scans. All this by using a smartphone, the PIX4Dcatch app, and the Reach RX rover.
Plug & play: fully integrated solution easy to grip on
The newly released PIX4Dcatch app is at the core of the software part of the kit, enabling precise scanning for both photogrammetry and LiDAR projects. The hardware part features the Emlid Reach RX RTK rover equipped with an ergonomic handle and accessories. Emlid Reach RX is natively integrated with PIX4Dcatch and provides real-time positioning via NTRIP. To begin scanning, simply select Emlid in the RTK settings of PIX4Dcatch and add your NTRIP network credentials. The integrated solution doesn’t require additional setup or surveying skills—anyone on the team can use the kit, ensuring effective data collection as they move around the asset.
Emlid Scanning kit with a handle
The Scanning kit comes with a handle with a left-to-right switch for a stable grip
Proven workflows across industries
Easy to deploy yet highly accurate, the Pix4D & Emlid Scanning kit will become an important asset for professionals and non-surveyors in a range of applications:
  • Underground utility documentation for companies implementing Subsurface Utility Engineering (SUE) best practices.
  • Construction inspection. As-built scans with less time spent on data collection and drafting.
  • Volumetric measurements. Effortless stockpile or cut and fill calculations.
  • Crash reconstruction. Quick roadway clearance with easy and accurate accident scans.
  • Combined aerial & terrestrial surveys. Creating a complete site view that enriches drone imagery with terrestrial scans of areas inaccessible to a drone.
Hardware: survey-grade GNSS by Emlid
Emlid Reach RX works with any correction network (NTRIP) or a GNSS base station broadcasting RTCM3. The rover gets a fix in under 5 seconds even in challenging conditions and ensures centimeter-accurate positioning. Apart from the scanning tasks, it can be used with the survey pole as an RTK rover for data collection and stakeout. Designed for urban surveying, Reach RX has the following specs:
  • Rated IP68, sealed and protected from water and dust.
  • Weighs 250 grams and can be carried in your pocket.
  • An industrial-grade battery handles both high and low temperatures and provides 16 hours of work on a three-hour charge. You can charge it on the go from a USB port or power bank.
Besides Reach RX, the Emlid Scanning kit includes additional accessories: a scanning handle, ground tags (5 pieces), and a carrying case.
Emlid Scanning kit
Emlid Scanning kit is ready to collect data right out of the box
Software: data capture & photogrammetry by Pix4D
The Emlid Scanning kit powered with the Pix4D software fully covers the entire field-to-office workflow for creating digital models.
The PIX4Dcatch mobile app in combo with Reach RX enables you to use your smartphone for scanning with RTK precision and generate a digital model within minutes. The captured data is stored online in PIX4Dcloud which allows you to annotate, measure, and share scans with stakeholders.
You can also verify geolocated positions and visualize the project in Augmented Reality. With PIX4Dmatic and PIX4Dsurvey, you can go even further if you need to analyze and extract insights from both terrestrial and aerial data. These apps provide online and offline processing, advanced photogrammetry capabilities, team collaboration, and AR for CAD overlays.
Digital model with the Pix4D & Emlid Scanning kit
Combined aerial and terrestrial survey with the Pix4D & Emlid Scanning kit
How to order the Scanning kit
The Pix4D & Emlid Scanning kit is available from the Emlid online store. You can also order the Scanning kit from the official dealers’ network. Read more to discover how the new Scanning kit can contribute to your projects.
Explore and order
In contact with Pix4D to try and get a demo onsite… since I already have an RX. :wink:
Would this work with a RS2 instead of an RX?
Also interested in whether an RS2 can be used instead since I have several but no RX.
Seems like it “could” if an extension was used and somehow being able to use/modify the proper antenna offset in the software? Little bulkier obviously.
Better start eating your spinach…
Lol hey Michael!
I’ll probably end up with 1 buff & 1 skinny arm like a fiddler crab :crab:
Does anyone know if this less expensive system with Lidar & GPS then some of the more costlier systems out there, be used to easily produce an accurate CAD drawing of the model?
It appears I need to subscribe to a $199 a month Professional plan to be able to select the RTK over Bluetooth option. Otherwise I am stuck with using the gps sensor in my phone.
Am I missing something? Otherwise I might as well just use my DJI Osmo gimbal with my iPhone.
I don’t see any mention of a subscription plan in any of the marketing done by Emlid and Pix4D. I knew I would need to pay to process the data with Pix4D proprietary software. However, I had to option to export the data and process it with another software.
Please reply and advise. I apologize if I have this wrong, but I just spent hundreds of dollars for 3-6 foot accuracy when I need cm. Accuracy.
Welcome to Pix4D. Everything is a subscription. Kind of like Trimble Catalyst…
Kinda like EVERYTHING these days. :poop:
“You will own nothing and be happy”.
Would be nice to see a LiDAR version, possibly using iPhone with LiDAR capability or something even better for larger ranges and better accuracy than photogrammetry solutions. A mount for the RS2/+/3 etc too that keeps it aligned plumb with rover pole.
Seems a different 3rd party may have already developed this by now?
I’m wandering if the M2 couldn’t be used, I don’t see why it couldn’t. The only draw back would be the battery to power it but I think there are credit card sized batteries now with sufficient power for the M2. You could Velcro attach the battery/M2 to the holder somehow. The helical antenna would work with an adapter to the mount.
I wouldn’t worry so much about the antenna offset factor, you could basically make an adapter to mimic the RX antenna phase center height .
Another advantage with the M2 would be you could log data, unlike with the Reach RX…
Hi guys,
This setup with Pix4D is working only with Reach RX.
Besides, regarding working with LiDAR equipment in general, streaming the position from Reach to LiDAR may be an option to get real-time coordinates for the survey.
Well, Pix4D got the incompatibility issue with GEODNET and Emlid Caster solutions. I ran about 6-7 tests this morning and uploaded a couple to Pix4D Cloud.
Gotta watchout for overspray… Although I loaded the images in Metashape as well and it cleans up nicely. Interesting note when you download all data and pull images into Metashape there are point confidence and depth maps files. I’ll have to dig into that later, but image alignment errors on 50 photos was 0.03-0.21ft. Not bad.
Here’s a section of road for grade check and asbuilt manholes. Note the shadowing effect on the left-center of the road. Don’t scan with the sun at your back. It actually created a double layer in one area. More to come.
Question now is how do you upload from mobile and use GCP’s…
A W E S O M E !
:grinning:
CIP concrete wall.
Pix4D Cloud
Metashape
Electric Ductbank Asbuilt Pix4D
Metashape looks like a better output than the other two to me. I’ve tried pix4d at the beginning before I bought Metashape and there was just something about it I didn’t really like. It seemed too cumbersome for me compared to Metashape. I’ve learned a lot with Metashape, there’s a lot you can do as far as tweaking the final product. It just seems it’s easier to use for me.
To me it’s like the Apple sandbox (Pix4D) vs Android (Metashape). You can’t even edit or filter the tie-points in Pix4D so their results will never be quite as accurate or as clean. Optimizing the tie-points and work area and then using the gradual selection tools in the right order makes the rest of the process faster.
My biggest issues with the scanning solution with Catch and the Pix4D workflow are,
  1. No way to clean the tie-points.
  2. No GCP when using mobile upload.
  3. Unable to use the site localization. This is the most important in our scenario. We should eventually be able to reference the localization from Flow or import the transformation values. Or at the very least be able to pick a couple of control points and localize while in Catch.
Haven’t tried it yet but found this…
And here’s the source of what Android devices support ARCore and allegedly Catch. Must support the Depth API.
