What is the minimum data rate should be between the base and rover? I am using a LoRa module with the 9.6kbps. Is this enough?
In addition, Does the correction data need to be sent real-time?
There’s no fixed value for minimal data rate value since it depends on messages that are transferred, their frequency, number of visible satellites, etc.
In RTK mode the corrections have to be real-time, but little delay is acceptable.
