hi all,
I have tried here , here2 and here+. all of them work except the here+.
As soon I as connect it, ardupilot won’t start, and the baro test fails…
could it be a problem in the i2c communication ?
I would appreciate some help.
as you can see in the picture, I have tried two different navio with two different software and two different rasspberry pi 3 and 4. they all exhibit the same problem
my cables are fine, pinouts are fine. same cables work fine with here and here2.
I’ve been “droning” for 3 years. playing with these toys is my daily job… I’m wondering if you guys have already made a here+ work with a navio. if so, I will go back and try to find the issue… but if they are not compatible. I will just not use it for now and look for another alternative.
Thanks
Currently, I don’t see clear reasons for connection failure between Navio2 and Here+. If the barometer test on Navio2 fails only when Here+ is connected, it might have something to do with the receiver. Please check that the device works with other available hardware.
Let me correct my previous comment a bit. I believe there is a contention on the I2C bus. It seems that the Here+ device may use the same address as Navio2’s barometer. If it’s so, it won’t be possible to integrate them.
