The data display on ReachView has delay?
And how long is the delay?(Depend on my internet?)
The final question is how to test whether the delay exist or not?
Depending on your epoch collection speed, you will see some delay. Usually not more than 1 second at worst.
Hi @qzmp69375,
The update rate is responsible for how frequently the receiver calculates and reports its position. Reach supports update rates from 1 to 14 Hz. For example, if you choose the 5 Hz rate, you will see a new reported position 5 times a second.
The delay due to the signal transmission itself is quite small. The Wi-Fi signal quality and the mobile device model can influence the delay, but I can hardly provide you with the instructions of how the precise variation can be measured.
