Hi
I perform a test collecting some points in RTK and in single mode.
I post processing the single with the rinex produced by the same station that provided me the RTK corrections but the result (of postproc) is quite different form RTK.
The purpose of the test was
1)collect some point in FIX RTK (test rtk.csv file)
2) collect the same points but in single mode (testsingle postproc.csv)
After I would like to post process the single mode using the rinex provided by base station that provide also the rtk corrections to check the accuracy/correctness of both approach.
Can you show me how you can see in the emlid studio the timestamp of data?
I see from your screenshot that you use the RINEX header position for the base coordinates. Please note that these coordinates have a few meters of accuracy.
To have accurate positioning, you need to enter the exact coordinates of the base in LLH or XYZ format. You can get these coordinates from the NTRIP service provider.
I’ve also noted that you have different numbers of points in the RTK file and the PPK file, so it’s unclear what points should be compared. It would be great if you’d specify points for comparison.
