i have the same problem too
both of my telemetry modules are flashing green
although i have successfully connected them before via USB and got a solid green light.
but after i flashed the NAVIO img again into the SD card and did the setup all over again. everything went smooth until i got to the telemetry part.
Hi Ed,
I’d ask you to elaborate a bit more on the issue with the telemetry configuration. Could you please specify which launching options are enabled in your file? What settings in Mission Planner are applied when you try to connect to it?
