Is it possible to have telem 1 and 2 as -A…192.xxx.xxx.102 and -A…192.xxx.xxx.103 ?
Hi!
You can do it like this:
-A udp:192.168.1.2:14550 -C udp:192.168.1.3:14550
or -A udp:192.168.1.2:14550 -D udp:192.168.1.3:14550
Thank you very much Ivan
Hello Ivan. I tried that and I can not connect if there are 2 UDP addresses in the file
Hi, Barry.
Could you please post what is in your file?
Did you reload configurations with sudo systemctl daemon-reload
after the file was changed?
Let me try that one more time and I will let you know
There you go. Did this and did daemon reload. If it is like this i can not connect on any of those addresses
Could you please post output of sudo systemctl status arducopter.service
It seems that you mixed up the pictures and posted the same pic twice.
Oops. Sorry I’ll upload the correct file
You can close this thread. Seems to be working. :-).
