What is needed to get data by tcp
Hi Gosai,
What do you mean by getting data?
Do you want to download logs/survey projects?
Or are you going to output Reach position in real-time?
Receive correction via tcp instead of lora radio
Hi @grakeshgiri,
You need to connect both Reach units to one Wi-Fi network for it.
Please, don’t use Reach own hotspot, as its range isn’t very large.
Then you need:
- Open Base mode tab on the base unit
- Choose TCP option
- Configure it as a server, enter “localhost” in the address field and port number (for example, 9000)
- Hit Apply
- Open Correction input tab on the rover unit
- Choose TCP option
- Configure it as a client, enter the IP address of the base unit in the address field and the same port
- Choose RTCM3 format of correction messages
- Hit Apply
