I’m trying to post process the raw logs from REACH RS to get a static position. I’m using JUSTIN software where I require to input the antenna type. Also, while using the REACH M as a rover, we have connected it to Tallysman GNSS antenna. For this also, we require antenna type specification. It is not provided in the specification, seems…! Can anyone suggest.
Reach M+ and Reach RS+ are L1 receivers so they don’t require antenna calibration. That’s why you need to choose the “none” option for the antenna type in your software.
The only thing that may be essential for post-processing raw data from Reach RS+ is the distance from the bottom of the device to APC, which might be considered as 65 mm.
