Hi @lche,
Thanks for your patience!
Let me answer your questions below.
Let me explain this a bit more. Reach RS2 can record the raw data log, base correction log and position log. The base correction log contains the information that the rover receives from the base station.
However, currently, it’s not possible to output this data in real-time. You can download the full base correction log only after the survey.
On the latest v2.25.2 dev firmware version, you can choose to output only the GPRMS NMEA message at 1 Hz. However, the dev versions allow you to test the new features early so we don’t recommend using them during important fieldwork.
To choose this message on the stable version v2.24.2, you will need to output the position to a third-party board that will parse it and provide you with the necessary message only.
