I have two WiFi networks defined in wpa_supplicant.conf and a suitable priority set for them. But what happens if I want to override this priority and force connection to a particular network ?
I have tried wicd-curses and while it lists available networks and allows you to disconnect just fine it won’t let me connect. I did read elsewhere on this forum that the Navio wifi setup is none stock, maybe this is the cause.
Regardless I am sure there is some Linux command line fu I am missing to switch at will between networks ?
