Surveying with one unit and ppk with CORS station - settings?
Hello! I am trying to survey with one unit and then do ppk with the CORS station as a base. In the emlid flow app, there is a ‘correction input’ and ‘base output’ setting - what should I have these set to?
Hi Emily,
Welcome to our community!
When you’re collecting data for PPK processing, there’s no real-time correction stream. The receiver records only raw observation data. It means that you can set both Base output and Correction input to Off for the recording.
For the configuration of the raw data recording, feel free to check this guide from our docs.
Also, to perform the PPK in Emlid Studio, you’ll need raw data from the particular CORS for the same time period.
