-Start Survey project on rover side and enter antenna height. I assume this is the pole+antenna and connectors
-Start collecting points? But where do I enter Base antenna height?
Coud soneone put light over my head so we can start testing and compare with our actual suevey hardware?
Test purpose are to just setup the base, start it - start Rover and get fix. After that, just starr collecting points.
If you are using Reach as base, this is done under “base mode” menu with manual coordinates on base.[quote=“Pat_Savard, post:1, topic:6353”]
[/quote]
Hi, have you gone through Tutorial – Introduction | Reach RS/RS+ ? It will be a little easier for a FORUM member to answer specific questions. Welcome.
Antenna height setting for the base is only available in manual, as if you determine base position from averaging, measurements are already done at the ARP and height of the tripod does not matter.
