Struggle to get a fix with emlid studio
It’s the first Time i’ve worked in ppk.
Here is the way i’ve worked :
The base is an rs+ with ntrip corection in good condition.
The rover is an rs2+ working in single solution in less good condition but not so bad.
I’ve handeled to obtain 82,6% of fix points with emlid studio
On the other hand, the corrected csv has no fix points created
I can send all the folders (raw, csv)
Thanks for tour help !
Fabian
Hi Fabian,
The files could be of great help! You can post the links here or, if you don’t want to share them publicly, just drop the files to support@emlid.com and we’ll take a look.
Hi everyone,
Just wanted to update here that the issue was resolved via email. When you capture points in Emlid Flow for Stop&Go mode, please use averaging timer, not instant collecting. If the averaging start and averaging end are the same, Emlid Studio won’t process such a CSV file.
