Dear forum members.
After some research on the forum I almost solved my problem, but I still have some questions .
How can I control my Storm 32 gimbal via the USB port of my RPI2
This is my setup:
NAVIO 2 + RPI1 --> USB to TTL --> Storm 32 V1.32 controller
telemetry via 3DR (USB) or WIFI dongle
Running the latest image available.
I managed to redirect the telemetry to the USB port instead of the uart connector but i’m unable to do this for the storm 32.
I have read here and there some answers in the forum but it’s all scattered information, i’m not getting the whole picture.
For you information the storm 32 runs with a baudrate of 115200.
Can somebody explain me what line I need to add to which file? I tried to add “-C /dev/ttyUSB1” but that didn’t work…
See below
/etc/default/arducopter
Default settings for ArduPilot for Linux.
The file is sourced by systemd from arducopter.service
TELEM1="-A udp:255.255.255.255:14550:bcast"
TELEM2="-C /dev/ttyUSB0"
"-C /dev/ttyUSB1"
Options to pass to ArduPilot
ARDUPILOT_OPTS="$TELEM1 $TELEM2"
-A is a console switch (usually this is a Wi-Fi link)
-C is a telemetry switch
Usually this is either /dev/ttyAMA0 - UART connector on your Navio
or /dev/ttyUSB0 if you’re using a serial to USB convertor
-B or -E is used to specify non default GPS
Type “emlidtool ardupilot” for further help
Can somebody point me into the right direction thank you!
ps: I could connect it to the UART port, but unfortunately the connector broke off…
thank you for your help
