I can not get the CSV file to work with Stop and Go. What am I doing wrong?
Hi @Culpy
Welcome to our community forum.
I had a look at the CSV file you shared. I noticed that the first collected point is in local coordinates, while the rest are in global coordinates. Stop and Go needs more details in its CSV—this point seems to have been imported, so it should either be removed or imported properly.
Also, the averaging time of most of the collected points is currently less than one second. For Emlid Studio to process the data, the time difference between “Averaging start” and “Averaging end” needs to be at least one second. You can simply edit the CSV file and manually adjust the averaging time.
Give it a try and let me know how it goes!
Hey Mohammad,
thanks for the reply. I tried doing what you said and it still isn’t working. I put the file in the drop box, called: Veteran_Memorial_Parkway_UTC_Adjusted (1)
This might not be the issue, but if you got the csv from Emlid360 instead of the Emlid Flow app it will not work. That tripped me up last time I post processed, but things could be different now idk.
Thanks for the reply! I took the csv from Emlid Flow app.
Hi @Culpy,
I wasn’t able to find the updated CSV file in the post. Could you please share it again, along with the following files -
- Observation files from both the base and the rover.
- Navigation file from the base or the rover.
I’d like to recreate the issue on my end to understand better what’s going on. Since the files might contain sensitive information, I recommend sending them to our email support@emlid.com.
