On the forum I see a lot of Reach RS mounted in unique ways. Having a bubble level would a step toward better leveling (and centering over a point) for those who don’t use the traditional tripod and tribrach.
I humbly beg you not to judge the misshapen rendition of Reach RS that follows:
… and I challenge you to create an STL file for this concept bubble level attachment and share it here with everyone!
If I get brave enough, I may take up the challenge myself, but I figured it was better to put the idea out there and see if there were any talented individuals who wanted to tackle it.
It would be nice to provide information on how to obtain the bubble level which fits the design and also the screw size and length.
Bonus points for a second design that incorporates two bubble levels. One of standard sensitivity and one of higher sensitivity.
Done.
Its a multitool.
5/8 tread bottom, 1/4 top. Made of cnc alloy or similar. It has a slide in/out arm with build in bubble. and i was thinking of a coffecup holder on the other side… maybe to much with a cupholder??
It also has hole for cable and a lock tight screw so the RS would not turn it self of. And finally a keyring hole to strap i to anything. reach.zip (12.0 KB)
Yea… a cupholder would probably make a mess one day or complaints about to much drinking at work.
Could swap it with a dual bubble ? Offset arm with 5/8 thread so you can slide RS outside the center of a tripod?
I actually have another idea, but have to do some actuall work now
