Is it possible to have a step by step procedure to establish a network conneciton with a DUB-E100 a reach module?
Thank you!
Thank you!
ssh
connection to Reach over Wi-Fi.Using that ssh
connection, do the following:
ifconfig | grep enp
- See a device with name similar to: enp0s17u1
ifconfig enp0s17u1 192.168.3.20
- Substitute your correct device name above
- Substitute IP address 192.168.3.20 above for an IP address compatible with your LAN addressing scheme.
Now you can access ReachView in your browser by using that IP address, like so:
You can also make an ssh
connection using that IP address.
If you want your Reach module to automatically do this, then you will have to search the Intel Edison forums.
Here is a link to start your search:
https://communities.intel.com/thread/55506
