I did GCP (ground control point) survey
emlid reach M + is used for gcp survey and processed by static methods
static processing results have been fixed 100%
emlid measurement results are used to be used as check points in photo processing at agisoft
error results in agisoft: East err 0.49 m, North err 1.02 m, Alt err 1.38 m.
results must be below 10cm
anyone can help?
You’ll get a a lot of false reflection (multipath) from those tree. Raising up the antenna will decrease this drastically. In your environment, preferably 3 meters or more.
Also make sure your base is located at a site with very good skyview. That’s essential for good accuracy.
