Good day,
I created a Ground control point, did a static report for it and also I connected to caster.emlid.com and used a mount point there but my results differ in approximately 7 decimeter. how is that?
Are you sure you have used the same base position?
Hi Linus,
I received your email and got that you used the same base position.
Did you collect the point in RTK in WGS84? Can you share the CSV file and the logs you used for post-processing? You can do it via email if they contain sensitive info.
