I think I am making mistakes, but I don’t know what they are. I am looking for some guidance.
I set an RS2 as a base on an unknown point (1.83m static receiver height). I recorded a 23-minute raw log file after obtaining a Fix with a local CORS station. During the entire time, the receiver showed a Fix in Emlid Flow. I was able to convert the raw file to RINEX for an OPUS solution, which I obtained.
I wanted to compare the OPUS solution to the base marker position in Emlid Flow (using an average Fix with a 10-minute averaging time). I also wanted to compare the base marker position to the Static Processing position output from Emlid Studio.
When processing a Static Receiver position in Emlid Studio using the static processing feature, the response shows a 100% FLOAT, not a Fixed position, but showed a Fix 100% of the time when recording the raw log file in Emlid Flow. I don’t understand why. I must be doing something wrong, but don’t know what it is.
I have all the files (receiver raw, CORS observation, OPUS solution, and static receiver processing) in a zip file ready to add to this post, but don’t know how to add them.
Any help is appreciated.
