What is the public IP-adress in the reciever and where to see it?
Do you have a static public ip sim card installed?
This would only benefit you on the base for corrections in most applications.
In Sweden only companys can get static ip adress! Should be better with IP v6.
I found it via crome in the android
That’s the same here in Canada. But since our tax system is so messed up most people are companies anyway.
Hi Jan-Olov,
A static IP address for Reach RS2 can’t be set in a Wi-Fi network. The only way to do it is to assign a static IP for a SIM card with your cellular network operator. Please note that if you use a SIM with a static IP, everyone who knows the IP address can connect to the receiver.
