Good day all,
I’m sure that I’m missing something simple but I’m not having much luck staking out points that have been loaded into Emlid Flow. I searched around a bit and didn’t really see anything that explained the process.
Thanks,
Frank
Good day all,
Thanks,
Frank
Pick a point from the screen, then the measurements will direct you to it
When you say pick a point from the screen, how do you do that? I know this is simple but I dont get it.
Here, sorry about the resolution, it only allows 4 mb
Hi Frank,
We also have the guide that shows how you can stake out the points in Emlid Flow. Hope this helps!
Thank you, I knew it would be simple.
Thank you.
