Hello, what is your experience using RS2 for stakeout with Microsurvey FieldGenius or Carlson SurvPC/CE app. I use my RS2 as RTK rover, I get CORS correction through 3G modem. Sometimes it “freezes = no coordinates refresh” when I do stakeout. It is drive me crazy. I use this setup guide Setup Guides for EMLID and FieldGenius for Windows - Powered by Kayako Help Desk Software and and I have my RS2 connected to my windows 10 tablet or my windows mobile handheld trought Bluetooth COM PORT. What am I doing wrong?
Hi Patrik,
May I ask you you share the Simple system report so that I could check the settings? You can PM me with that in case it contains any sensitive info.
Thanks for help.
ReachRS2_Simple_Report.zip (1.1 KB)
Hi Patrik,
Thanks! I’ll check that and get back to you.
Hi Patrik,
It seems the settings are ok. Is there any chance you could record a screencast when the issue occurs?
Hello, finally the following solution helped me. I set up NTRIP corrections directly in Reach. And the stakeout is pretty smooth. Originally I had the NTRIP correction set in Fieldgenius / SurvPC app, and that was the problem. It measured well, but it froze when I do stakeout. Thanks.
Hi Patrik,
It’s interesting. We’ve tested receiving corrections from Filed Genius via Bluetooth and haven’t faced such issues. Thank you for sharing this! We’ll check it once again.
