I would like to know if others see this problem when setting out with reach view 3.
When I was doing stakeout work and I am already a few cm from the point to be marked, in the reach view 2 application the screen appeared with the point in green as shown in the first image. This was very practical since it showed in a graphical way if you are far or near and where to move the equipment to get to the point.
The reach view 3 application does not have it and it was extremely slow for me.
Thank you for the request! There are indeed some differences in the Stakeout GUI of the apps. We’ll consider adding the green marker to future versions of ReachView 3.
Do you work with the latest ReachView 3 version? In case you face any issues with ReachView 3 performance, please elaborate on it. It will help me check what might be wrong.
I am working with version 5.6.
In addition to those described above, when I try to find a point to stake out from the list (attached image) it does not appear, I must select it from the map. This makes the process even slower.
Could you please elaborate a bit on the issue? What happens when you tap on a point from the list? I’ve just checked that I can choose a point for stakeout this way fine.
