mas4649
(Mas Hro 514tkb)
1
I installed APM and tried to run. But Pi spits error as below.
SPI: unable to open SPI bus /dev/sipdev0.2: No such file or directory
I checked that SPI is enabled and both sipdev0.0 and spidev0.1 exist.
But I cannot find spidev0.2.
How can I add spidev0.2 ? Or any other problem?
I appreciate all the help I can get.
Hi, did you install our image?
mas4649
(Mas Hro 514tkb)
3
Thank you for your response.
Yes, of course. But I installed older version raspbian image and apm-navio2 because of problems with latest version.
You need to use the new image with Navio2. Which problems are you experiencing with it?
mas4649
(Mas Hro 514tkb)
5
With latest raspbian, Pi did not start up only to show color square.
And I couldn’t install latest apm-navio2 by below command.
sudo apt-get install apm-navio2
But I installed older one successfully by command with URL. I may be able to install newest apm-navio2 with URL, but I don’t know the URL of it.
