I am using Navio2+rpi2 with the following image:
$ uname -a
Linux navio 4.4.36-a7765e7-emlid-v7+ #41 SMP PREEMPT Mon Mar 20 18:48:32 MSK 2017 armv7l GNU/Linux
I was running some spi transfer tests which look like follows:
#include <unistd.h>
#include <fcntl.h>
#include <sys/ioctl.h>
#include <linux/types.h>
#include <linux/spi/spidev.h>
#include <cstring>
#include <cstdio>
#include <time.h>
int transfer(const char *spidev,
unsigned char *tx,
unsigned char *rx,
unsigned int length,
unsigned int speed_hz = 10000000,
unsigned char bits_per_word = 8,
unsigned short delay_usecs = 0)
spi_ioc_transfer spi_transfer;
memset(&spi_transfer, 0, sizeof(spi_ioc_transfer));
spi_transfer.tx_buf = (unsigned long)tx;
spi_transfer.rx_buf = (unsigned long)rx;
spi_transfer.len = length;
spi_transfer.speed_hz = speed_hz;
spi_transfer.bits_per_word = bits_per_word;
spi_transfer.delay_usecs = delay_usecs;
int spi_fd = ::open(spidev, O_RDWR);
if (spi_fd < 0 ) {
printf("Error: Can not open SPI device\n");
return -1;
int status = ioctl(spi_fd, SPI_IOC_MESSAGE(1), &spi_transfer);
int speed;
int ret = ioctl(spi_fd, SPI_IOC_RD_MAX_SPEED_HZ, &speed);
::close(spi_fd);
return status;
int main()
struct timespec t_start, t_end;
int dt_us = 0;
int tmax = 0;
float tavg = 0;
while (dt_us <= 1000) {
clock_gettime(CLOCK_MONOTONIC_RAW, &t_start);
// spi transfer
unsigned char tx[21] = { 0 };
unsigned char rx[21] = { 0 };
tx[0] = 0x3B | 0x80;
transfer("/dev/spidev0.1", tx, rx, 21);
clock_gettime(CLOCK_MONOTONIC_RAW, &t_end);
dt_us = t_end.tv_sec * 1000000 + t_end.tv_nsec / 1000 - t_start.tv_sec * 1000000 - t_start.tv_nsec / 1000;
if (dt_us > tmax) {
tmax = dt_us;
tavg = (0.01 * (float)dt_us) + (0.99) * tavg;
usleep(50);
printf("Max (us): %d\n",tmax);
printf("Avg (us): %d\n",(int)tavg);
I should mention that I launch this test on a reserved cpu core (with isolcpus=3
at boot and by launching the test with taskset 0x08 chrt --rr 99
I have noticed that if I wait long enough, this program will stop, i.e. at one point the spi transfer will take more than 1ms. I have typical average transfer times of around 60us, here’s an example of output:
Max (us): 1409
Avg (us): 67
Running following cyclictest
I obtain a max latency of about 250us:
$ sudo ./cyclictest -l1000000 -m -n -a0 -t4 -p99 -i400 -q
# /dev/cpu_dma_latency set to 0us
T: 0 ( 2235) P:99 I:400 C:1000000 Min: 7 Act: 9 Avg: 11 Max: 235
T: 1 ( 2236) P:99 I:900 C: 444431 Min: 7 Act: 11 Avg: 11 Max: 224
T: 2 ( 2237) P:99 I:1400 C: 285682 Min: 7 Act: 10 Avg: 10 Max: 194
T: 3 ( 2238) P:99 I:1900 C: 210485 Min: 7 Act: 9 Avg: 11 Max: 109
I don’t really understand why there would be such discrepancies in spi transfer times; maybe I am doing something wrong here…
At one point I suspected the ntp server to interfere with my time measurements, but the results are unchanged when I turn off the ntp updates with sudo /etc/init.d/ntp stop
(moreover, from what I’ve read CLOCK_MONOTONIC_RAW
is not affected by ntp updates).
I would be happy to read your thoughts !
Cheers
