hello everyone. I recently purchased the navio2 and Racerstar RS20A BLheli_S 4-in-1 ESC. I can’t get the navio2 to use either one of the oneshot protocols. And the ESC doesn’t support PWM. What should I do?
Hello,
There is a bug somewhere with 3.6x arducopter preventing Oneshot to work with Navio2.
Oneshot 125 was fine on my Navio2 with Arducopter 3.5.5
If you have the latest Navio2 image (2019) you can use Emlidtool to choose Arducopter 3.5. It is the arducopter 3.5.x (maybe 5 or more) from Oct 3, 2018.
Marc
How do I rollback the version of arducopter to 3.5.5?
BTW, thank you for your quick response.
Connect with SSH to your card, run Emlidtool ardupilot, stop arducopter, quit emlidtool then rerun emlidtool (without rebooting the card). You will have access to the config menu.
Marc
It wont let me select anything but 3.6 for the “choose your version”
We have to check. I have emlid-raspbian-20190227.img copied to my Navio2 SDCard.
Enter the command cd /opt/ardupilot/navio2
then ls -l
The result:
If different, be sure to have the right emlid image installed.
When running Emlidtool you should have access to 3.5 version
Marc
Thanks I will give that a try. However, I was testing out the Servo.py file from emlid’s github repo and the motors were behaving erratically.
this repo: GitHub - emlid/Navio2: C++ and Python sensor examples for developers
and this file:
import sys
import time
import navio.pwm
import navio.util
navio.util.check_apm()
PWM_OUTPUT = 0
SERVO_MIN = 1.250 #ms
SERVO_MAX = 1.750 #ms
with navio.pwm.PWM(PWM_OUTPUT) as pwm:
pwm.set_period(50)
pwm.enable()
while (True):
pwm.set_duty_cycle(SERVO_MIN)
time.sleep(1)
pwm.set_duty_cycle(SERVO_MAX)
time.sleep(1)
Sorry but I mislead you.
I was running updated version of 2018-05-25 emlid image.
2019-09-27 image is missing the 3.5 directory.
Marc
I hope you see my latest msg. 3.5 directory is missing from 20190227 navio image.
I was working with the updated 20180525 version. If you have the old image on your computer you can flash it on the SDcard and update upgrade to the latest version. Arducopter 3.5.5 will be available to use with Oneshot125.
Marc
Where can I download the older images?
